505 has a 2.5 Stroker engine. They claim 185HP. What issues does a Stroker cause? Do they play nice with the TJ sensors? Will they run with the stock fuel system?
I realize their site is going through revisions, but that has to be the most bare bones product description I've ever seen.505 has a 2.5 Stroker engine. They claim 185HP. What issues does a Stroker cause? Do they play nice with the TJ sensors? Will they run with the stock fuel system?
I understand the the 505 reputation part. If it’s $2-2.5k for a rebuilt 2.5 and for $500 more you can buy this, then why not?505 has a shit reputation for what it’s worth. I also wouldn’t put a dime into doing anything to a 2.5.
Many say probably not. But there are AX5s living behind v6 and v8s.Can the transmission handle it?
AA sells adapters. Lolhttps://wranglertjforum.com/threads/1997-2002-jeep-wrangler-tj-2-5-turbo-install-guide.33022/
https://wranglertjforum.com/threads/2-5-turbo-build.49276/
I really doubt there is a AX5 living behind a V-8. Maybe if you drive super easy on it but I just don't see it.
To summarize, just remember that a stroker motor is a standard engine, but with an increased stroke in the cylinder. This increases total displacement resulting in more torque and more horsepower.
https://www.novak-adapt.com/knowledge/transmissions/manual/ax5/AA sells adapters. Lol
Just looking at options. I really am liking the GM LV3 4.3. The v6 may give me plenty of room to move things forward enough to get this done with a doubler.
I think a Magnum swap is a no brainier of I'm swapping any motor in aTJ.
I would not assume it is making 4.0 power based solely on their 185 number. I would want to see the torque and power curves. My guess is that the 4.0 still makes way more torque down low.I understand the the 505 reputation part. If it’s $2-2.5k for a rebuilt 2.5 and for $500 more you can buy this, then why not?
If we can bolt in 4.0 power into a 2.5, why not?
We can leave 505 out of this conversation to simplify the discussion as there are other options out there.
Another Stroker was rated at 145hp. Which is hardly worth the effort.I would not assume it is making 4.0 power based solely on their 185 number. I would want to see the torque and power curves. My guess is that the 4.0 still makes way more torque down low.
But that’s just my guess - don’t know for sure. Does 505 publish the dyno results for their stroker?
