I suspect as long as the engine is slightly newer than the Jeep, has all the emissions connected and the engine is running well; it should pass.That’s awesome! They said it couldn’t be done. With the strict codes they have in cali does he get it to pass their inspections?
So in my mind I begin to question charts that don't show the torque and horsepower lines cross at 5252 rpm.Those charts bug me with different scales for hp and tq. Whats with the 360 torque curve?? Why is it so arched??
I can't see the LV3 as being an easy swap/inexpensive swap.Those numbers are hardly worth the swap if accurate. The LV3 gm 4.3 has better numbers and might save some room?
They would if the scales on both sides were the same. Manufactures do that "modified scaling" to push both traces further to the top.So in my mind I begin to question charts that don't show the torque and horsepower lines cross at 5252 rpm.
Huh must be that " new math " we hear so much about!
The Ls does have a lot more support. With more potential should someone decide they need more HP.I can't see the LV3 as being an easy swap/inexpensive swap.
No P/S bracket provision. They all run electric racks. The engine doesn't pull enough vacuum. You would need to run a separate vacuum pump for the brakes or figure a way to run a hydro boost.
Fly by wire throttle.
Trying to get the electronics to play nicely.
Running a return line for the fuel system.
In the long run, it's probably less $$$ to so an LS or 4.0 swap.
Yeah haven’t you heard? The old math is racist!So in my mind I begin to question charts that don't show the torque and horsepower lines cross at 5252 rpm.
I was reading a bit on the 5.2 swap. Is there anyone selling a plug and play harness? Or close to PNP?All I can tell anyone thinking about doing a V-8 swap is to open up their check books. The GOOD thing about using the Mopar engines over a Chevy or Ford engine is that you'll save a ton of headache trying to get things to play together. You aren't trying to get accessories to clear the frame or to fit. Next is the dash. The Mopar PCM mounts where the stock Jeep PCM did and it can communicate with the stock Jeep dash. If you swap in a Chevy or Ford engine from what I understand you have two choices.
1) Replace the stock dash with a custom dash. Meaning aftermarket gauges and mounting
2) Run two PCM's One PCM is for the engine you swapped in and then the other PCM is the stock Jeep PCM. So you have to run double sensors for some things.
And those charts don't tell the whole story. Go drive a Dodge Ram pickup or a Durango or a Jeep Grand Cherokee and see the pep they have. And while I'll agree that there is more support for the Chevy engine but that doesn't mean you can't get hop up parts for Mopar stuff.
The 5.2 (318) was the light duty V-8 while the 5.9 (360) was the work horse engine and if you'd ever driven a pickup with these 2 engines you'd know these numbers were off.
