My 97 Wrangler 2.5L stopped working on me a couple of weeks ago. I thought it was the fuel pump so I changed it out. Afterwards I did a fuel pressure test. It was hard to start but I was able to get it going after a while. I ran seafoam through the engine to clean the injectors and did a hot soak. After it sat for a while, it was hard to get the jeep running started. Again after a few more attempts I was able to get it running and drove around for a few minutes to clean the system.
When I got home. I killed it, then started it right back up. I decided to let it sit for several minutes and came back out to start it, but was not able to get it going.
I did a little research and thought it could be the ignition coil, so I just changed that out but it did not start. I checked the spark plug, but I am not getting a spark now. I swapped out the automatic shutdown relay with the A/C relay to try that as well.
I am thinking it could be the ECM, but I am not sure what to check before going down that route. I am a novice and have basic tools.
I appreciated your collective experience and any advice. Thanks
