Well, this sucks. I replaced the ball joints and noticed the camber was off on the passenger side front wheel. Took it to the alignment shop and sure enough it is out negative 2 degrees. The drivers is out to but not near as bad.
My question is: Is there an adjustable ball joint available that would correct this, perhaps in conjunction with a spacer(I forget what they are called but you guys know what I mean) behind the hub??
I've already found a dana 30 with 4.10 gears for 600 bucks, if need be I will buy it and re-gear the rear to 4.10's which I wanted to do anyway (just not this soon, money is tight these days) if I cannot correct the camber.
I want to hear from anyone that has had to correct the camber on a Dana 30
