I particularly like the 5.2 sticker touch on the side. You wouldn't even realize that wasn't factory unless you were really paying attention
I agree! Thought it looked pretty factory!I particularly like the 5.2 sticker touch on the side. You wouldn't even realize that wasn't factory unless you were really paying attention![]()
Thanks! Keeping it fuel injected, Just due to the ease of it and how everything is set up.Nice job on the bracket! Looks factory! Are you fuel injecting this beast or are you going with a carb? Just wondering.
Its quite simple actually, and there is a TON of info on the interwebz about it, but ill keep it simple - I am using an ECU out of a 2000 Dodge Ram 1500 base model that came with a manual transmission. This way the body harness will still connect to the ECU and the other 2 ECU plugs (engine side) will all plug in as normal. The ECU will communicate with my factory gauges as well. I didn't want to use the ZJ ECU because it was originally for an automatic, and it has a security system (the dreaded SKIM system that everyone always talks about, and causes your engine to cut fuel after a few seconds of running).Are you sticking with a factory ECU setup or after market Fuel management system? I was just wondering how you will get the stock wiring to match up with the engine harness and fuel management system.
Exactly! Seeing you're from MI, I'm sure you see things often on how control arm mounts will break off the frame, etc and people send it to be crushed because other "internet gods" from the southwest US (that have never seen salt) said it was junk and to get rid of it. Irritates me. The Safe-T-Cap panels can make it just as strong or stronger than it ever was. My last 99 TJ I bought with the frame ROTTED and the caps brought it back to life for many years to come I've lived in San Diego (when I was in the Navy) and the salt belt; its hard to educate people who have never dealt with it. Anywho, rant over.Looks great. You're making quick progress. Another Jeep saved from the scrap yard!
I already made the wiring harness, what I did is take the stock 4 cylinder engine harness and "blended in" what I needed to from the ZJ harness. I used the TJ harness because it would match the firewall plugs, and it was originally a manual trans jeep. If I would've used the ZJ harness I would've had all kinds of automatic trans stuff to cut out, and some other crap I didn't want to deal with. I pinned in ALL 8 injector wires into the TJ harness, that way I would have the correct lengths of wire for the injectors and wouldn't have to worry about lengths. Also a few plugs here and there were changed to match the sensors on the 5.2 engine. All relatively easy stuff, just a little time consuming. This is what makes this swap so great though, the fact that you don't need to go get some specialty ECU, or adapters, or run 2 ECUs, or anything crazy. Anyone can do it with very little knowledge on wiring. Hopefully this answered your question, but if it didn't, let me know and I will try to answer it as best as I can!![]()
Exactly! Seeing you're from MI, I'm sure you see things often on how control arm mounts will break off the frame, etc and people send it to be crushed because other "internet gods" from the southwest US (that have never seen salt) said it was junk and to get rid of it. Irritates me. The Safe-T-Cap panels can make it just as strong or stronger than it ever was. My last 99 TJ I bought with the frame ROTTED and the caps brought it back to life for many years to come I've lived in San Diego (when I was in the Navy) and the salt belt; its hard to educate people who have never dealt with it. Anywho, rant over.![]()
Yeah I’ll be pretty happy, especially since all 3 of my TJs have always been 2.5’s, so going up to a 5.2 should be nice. I did have an XJ with a 4.0 at one point, but thats besides the point. HahaIt's coming along nicely. I bet you'll be happy to have a V8 in there, huh?
It’s weird when I visit my friends in Phoenix and see no rust. Up here you see rust on the rear fenders of Ram trucks that are just a couple years old.
I bought a ‘99 with a bad motor from Kalamazoo about a year and a half ago. Salvaged the tub but got a donor frame from a ‘05. Still a work in progress but I’m trying to build it to last 20 years in Michigan.
Keep us posted on your progress.
I had looked into it, but the quote for that would be $345, which is insane in my opinion for a cheap set of headersNice Headers! Have you thought about having them Jet-Hot Coated?
Ceramic Header & Exhaust Coating | Jet-Hot
Ceramic Header Coatings by Jet-Hot improve the look and performance of your vehicle by reducing heat and corrosion. Learn why industry leaders recommend that you get your vehicle "Jet-Hotted".www.jet-hot.com
