2000 rpm jeep
toscatara
España
Hello everyone
I bought a jeep wrangler tj 4.0 with detroit locker dana 35, the car costs to climb more than 2000 rpm, the ratio is 3.07 according to VIN, what can I improve?
06lj
Oregon
I am not sure what you are asking.
If the engine does not go higher than 2000 rpm you may have a bad Crankshaft Position Sensor. Do you have a scanner to check for engine codes?
T
toscatara
España
[QUOTE = "06lj, publicación: 428306, miembro: 8421"]
No estoy seguro de lo que estás preguntando.
Si el motor no supera las 2000 rpm, es posible que tenga un sensor de posición del cigüeñal defectuoso. ¿Tiene un escáner para verificar los códigos del motor?
[/CITAR]
my question is if rpm is normal
thnak
