Hello everyone
I bought a jeep wrangler tj 4.0 with detroit locker dana 35, the car costs to climb more than 2000 rpm, the ratio is 3.07 according to VIN, what can I improve?
I am not sure what you are asking.
If the engine does not go higher than 2000 rpm you may have a bad Crankshaft Position Sensor. Do you have a scanner to check for engine codes?
[QUOTE = "06lj, publicación: 428306, miembro: 8421"]
No estoy seguro de lo que estás preguntando.
Si el motor no supera las 2000 rpm, es posible que tenga un sensor de posición del cigüeñal defectuoso. ¿Tiene un escáner para verificar los códigos del motor?
[/CITAR]
