M
motomick76
Guest
Oh, look, another LS conversion in a TJ. Yes, this thread is about another conversion, but I hope to alleviate and answer alot of confusion and offer some answers or advice. The goal with "Sarah" is to have a capable DD that can be very capable on the weekend. This project has taken a total of 5 years, and the shutdown gave me the time and motivation to finally finish her. Just 3 weeks ago I picked up the short-block from the machine shop, and as of last week I just need to add an exhaust and final tune.
There have definitely been alot of sweat and frustration, but in the end, I love the end result. Was it cheap - no. All of the 'small" items I did not figure in and found into the build added alot to the cost of doing this. The main factor was the LR4 I got. I thought is was pretty good. It came with a standalone harness and basic tune. As I started digging into the engine there was alot of issues and had to have the block decked, crank polished, cam bearings, etc - so a basic full rebuild. I estimate this added $2000-$2500 to the cost of the build.
This build though is very different than most LS conversions. I wanted to keep the NV3550 and dump the NP231 and add a NP241OR. I enjoy the experience of the 5-speed while driving, and I wanted something more robust and different crawl ratios than the 231 offered, so I went with a 241OR. I ended up finding a JK241OR with a 2-Low conversion. Also the main issue with the JK is there is no output speed sensor, as the wheel speed on JK's are at the wheels. The final part is the skid plate I chose, a UCF Zero Clearance Steel Skidplate. My combination, a 5-speed, 241, and the skid I found very little information on builds or information. With this I had to make major modifications to the shifter, and build my own transmission mount to the skidplate.
Also I tried to take alot of pictures as I could not find alot online. Visually seeing a object usually helps in answering questions with builds. I have included a link to the build for the pictures.
Here is the build sheet for "Sarah"
Engine:
* 2002 LR4 with standalone harness
* Summit #8712 Cam
* BBK SS Shorty Headers #40205
* Complete rebuild, new bearings, rings and seals
* G-body oil pan with baffle
* Standard GM 10.5” Flywheel and Luk #40-205 clutch
* Novak pilot bushing #PB-3901357
* Superior Radiator (TJ to LS) and 3000 cfm electric fan
* Dave’s Custom motor mount kit #LSEMT J-Kit
* Airtex #E7200M Fuel pump - 05-06 TJ fuel pump w/ ⅜” line
* Gates heater hose #28471 and #28480
* Dayco #71316 for lower radiator hose
* NAPA #9840 for upper radiator hose
Transmission:
* NV3550 5-speed
* B&M Sport Shifter #45048
* Novak adjustable clutch release bearing #TB3
* Novak adapter plate #375
Transfer Case:
* JK NP241OR with Teraflex 2 Low conversion
* Novak #SK3XR transfer case cable shifter
* Front driveshaft: stock
* Rear driveshaft: Adams Driveshaft custom build
Front Axle:
* Dana 30 LP
* Revolution Gear 4.88
* Detroit Locker
* Artec Dana 30 truss kit and knuckle braces
* Black Magic Vanco 15” brake kit
* Teraflex front cover
* Custom shock and track bar mounts
Rear Axle:
* Ford 8.8
* Detroit Locker
* Artec Ford 8.8 truss kit
* G2 Aluminum cover
* Black Magic reverse brake cable mounts
* Custom shock mounts
Suspension:
* Currie 4” lift springs
* Currie aluminum fully adjustable short arms w/ Johnny Joint
* Currie front and rear track bar
* Currie Antirock front swaybar
* Rancho RS9000XL shocks
* UCF Zero Clearance steel skid plate
* 1” body lift
* Outboard rear shocks
* ZJ tie rod conversion
Exterior:
* Smittybuilt XRC front bumper
* Smittybuilt XRC rear bumper
* Smittybuilt X2O 10,000 winch
* Custom fog and spot lights
* Round flush rear tail lights
* Custom cowl intake setup
* Custom hood latches
* Raised rear gas tank 1.5” inches
* Reverse lights in rear bumper
Interior:
* Auto Meter Gauge Pod - 90011
* Speedhut Gauges
* Pioneer DEH 6600BT head unit
* Alpine KTP 445-U amplifier
* Polk Audio DB 5251 component kit
* Polk Audio DB 6501 component kit
* Alpine MRV-MV250 Amplifier
* Pioneer TS-SW2002D2 8” subwoofer
Link to build pictures:
https://drive.google.com/drive/folders/1o8ATd-iapN2LtqdKENHXHjFidO63xXkB?usp=sharing
Engine:
* Summit #8712 Cam
Transmission:
* NV3550 5-speed
Transfer Case:
Front Axle:
* Dana 30 LP
* Detroit Locker
Rear Axle:
* Ford 8.8
* Detroit Locker
* G2 Aluminum cover
Suspension:
* 1” body lift
Exterior:
Interior:
* Speedhut Gauges
