- Joined
- Apr 20, 2016
- Messages
- 32
So, I began experiencing increase vibration when down shifting and in fifth gear around 60 MPH. When I crawled under my jeep to inspect the unversal joints, I noticed that the pinion seal in the rear differential was leaking. I further discovered that when in neutral, I could move the yoke on the pinion shaft back and forth. I'm assuming this is not supposed to happen and that the pinion bearing has or is failing. Is this a correct assumption?
Secondly, I know that I do not have a Dana 44 rear end. I keep noticing on some parts websites that there are two other posibilities - the Dana 35 and the AMC 30? How do I know which one that I have?
