2000 Wrangler Cigar Lighter Looks Unused, But Won't Work
chiineserocks
Maryland
I’m not mechanically inclined, so if you do decide to respond I do appreciate it, but try to “layman’s terms” it to me lol. Anyway, the lighter looks brand new and never touched. I want to plug my FM Tranemitter into the outlet, but it won’t work at all. I was told to just go to Autozone and get a 20A fuse and replace it. Would this be ideal? TIA!
Before buying a fuse, you can look at the fuse block behind the glove compartment and see if it is missing or blown. The side of the compartment should have a diagram that identifies each fuse and its resistance.
2000 year model fuse block courtesy of Google:
I managed to fix it. Simple fix, thankfully. It was just a bad fuse.
Since you stated it was a simple fix; hopefully the problem remains fixed.
With a blown fuse there is generally a reason WHY the fuse was found blown.
What ever was previously plugged into the cigarette lighter receptacle was internally shorted or was drawing too much amperage to operate.
Reactions: Tob and dvngdg
Or worse case scenario; plugging in a (good) load, completed a bad circuit in the Jeep.
