H hypnosteveo New Member Joined Mar 29, 2023 Messages 2 Location Louisiana Mar 29, 2023 #1 Jeep is making a grinding noise only when clutch is depressed. Once in gear, it does not make any noise and drives normally. Any ideas?? Your browser is not able to display this video.
macleanflood I break sh!t Supporting Member Joined Jul 24, 2021 Messages 3,944 Location Fall Creek, OR Mar 29, 2023 #2 Throw out bearing. And if you're in there you might as well go for it and do a clutch and pilot bearing. Had a lot of luck with Luk on Amazon. -Mac Reactions: Rickyd
BC Moto TJ Enthusiast Supporting Member Joined May 27, 2021 Messages 603 Location Bay Area SF Mar 29, 2023 #3 Something is wrong with the clutch, I would get in there and inspect it. Throwout bearing may be on the way out.
OP H hypnosteveo New Member Joined Mar 29, 2023 Messages 2 Location Louisiana Mar 29, 2023 #4 Thanks for the replies. Brought it to a shop I generally use for each repair and the tech drove it and called me and said my transmission is going out but from my research, it seems to me like the throw out bearing is the cause.
macleanflood I break sh!t Supporting Member Joined Jul 24, 2021 Messages 3,944 Location Fall Creek, OR Mar 29, 2023 #5 Of course they'll say that... You can swap the clutch in a weekend with some basic tools. I did mine in a gravel driveway. -Mac
