Wanted to show everybody my build I finally got around to doing ,here’s my 2002 Jeep Sahara with a 2 inch lift , shocks and springs by Pro-comp ,this also has 3/4 inch spacers in the front by zone off-road to help level out the front rake. A few other things I did was replace all stock bump-stop, also replaced the stock steering stabilizer with a Pro-comp one to match shocks and because it was recommended with this lift.
I know this might not be one of the best lift kits out there but for the money it’s great. Overall I loved the way it turned out. Drives Great !
No I didn’t have to mess with the track bars or sway bar links ,with this lift your stocks ones work fine ,only thing I had to do was drop the transfer case Because of the steep angle in the drive shaft I was having some driveline vibrations, but it’s a simple fix with some spacers and longer bolts.
Wheels & tires :
15x8 fuel lethals
32/11.50 bfg km2 mud terrain
No rubbing at all
Wheels & tires :
15x8 fuel lethals
No rubbing at all
