• It's time to cast your vote for the third annual Ride of the Year (ROTY) contest! The winner will receive a free BMB big brake kit compliments of Blaine. Click here to vote! Voting ends December 31st at 12 AM MST.
2002 Jeep Wrangler TJ with glowing red cats
Mitch8801
British Columbia
Hey Guys,
So recently I was on my way home and at a stoplight had a misfire in cylinder 2, and my exhaust sounded funny and fluttery, I was like 8 minutes away so I decided to drive it home and coast down hill. Long story short, I replaced the spark plugs, still had issues.
I checked my coil pack and it seems to be working fine. I swapped my injector 2 to cylinder 1 seeing if the code would transfer to cylinder 1, no codes.
I drove it around the block, the power seemed fine but noticed my front cat was glowing red so I went back into the garage.
Put in a new Mopar Crankshaft sensor as I had a code about 2 months ago for a bad cps sensor.
Here is a couple videos:
I also ordered a new o2 sensor as I also had a code prior, for 2/2 o2 sensor, haven't put that in yet.
After cps sensor install, new o2 sensor code P0135 pops up. that's bank 1 sensor 1.
Anyways
right now I'm thinking my front cat is clogged.
Any help is appreciated.
It's entirely possible , I just replaced both of mine on my 06 with a Flowmaster for 330.00 , and I an very pleased ..the media came loose in mine , threw a code, etc.
If the sensors aren't NGK , return them , and get NGK . Most others don't seem to work, just a heads up.
You can drop the Y and run a hair dryer down each and tell a lot .
Gotcha, Yes my sensor I bought is NGK as that's what I read around on here for the only good replacement. I have a flow master muffler and I like it, Ill check out their cats.
You my friend have clogged cats.
Not uncommon by any means.
And yes, if you aren't using NGK / NTK O2 sensors, you're going to have other issues.
See this thread for info on that: The Official Jeep Wrangler TJ Oxygen (O2) Sensor Thread
You think it is possible that a clogged cat could cause my engine to misfire, it still is quite shaky but I'm not getting a code other than the O2 sensor code
Oh yes, absolutely!
When my cats were clogged it was running like crap. Wouldn't go about 3000 RPMs, it misfired, and it was putting along almost like a steam engine at times.
The O2 sensors are providing all sorts of wonky feedback because the cats are clogged, so they are basically telling the PCM to do all sorts of weird stuff, thus why the vehicle is running so poorly.
Oh yes, absolutely!
Thats good news as I was stumped what else to check. Im trying to find a pre cat kit for my 2002 TJ. I am only finding ones that fit 04-06, are they interchangeable?
Awesome, O'Reilly sales an oxygen sensor Ranch that accepts a 3/8 ratchet , which inherently makes it an offset design and once you get it positioned correctly gives you a little more leverage... It's well worth it to soak those overnight in penetrant .
The job goes easier if you drop the front shaft.
Don't connect it in the back first -work from the back forward
New bolts is great , if you will notice the bolts are designed to only tighten so far and I like to use full thread bolts to increase the clamp down since you don't have a gasket.
Good luck all the way sir.
Reactions: Blondie70
Thank you sir, you think the 04-06 cats will work for my 02
I truly don't know , it seems a lot changed in 03... definitely do the research on the model year applications .
Keep us posted, when you do that, we all learn.
That'll cause a check engine light.
Clogged pre-cats can definitely cause misfires, it happened to my 04.
Thats good to hear Jerry, Did they change anything with the exhaust system in 04-06 compared to 02? I can't find a good deal on 02 cats
Update: I had to chop the pipe to remove the Y Pre cats and unfortunately it’s not them, the insides of the catalytic converters look fine.
so I guess bank 1 was running rich as the cat was red hot.
Guess it’s back to the drawing board. Any ideas?
I used to work in a muffler shop. The prime reason for glowing cats is fuel mixture problems.
Yup, gotta be running too rich in bank 1, what could it be? I’ve put new plugs, and 3/4 o2s are new. The only thing that’s left is coil pack and injectors? I’m going to swap my buddy’s coil pack in to test the coil pack.
UPDATE: Good news! Turns out it actually was the coil pack. Swapped In my Buddys coil pack and the jeep ran mint. I will be doing a quick little how to post on the repair and the symptoms
