Howdy all. So I'm getting the fix it list narrowed down pretty good on Gertie (daughters jeep) so today after tackling a bunch of smaller jobs ( 2 inch lift, rear transfer case seal,steering box replacement, track bar bushings etc etc) it's time to tackle the leaking auto trans shifter seal.
I managed to get all the skid plate bolts loose except for one which decided to spin the nut with it, So will dremel that one off and replace. Any tips tricks on replacing it ( the seal ) Can one lower the transmission/transfer case enough to gain access or is it best to drop trans pan and go from the bottom.
I eagerly await advice from the hive. Before disassemble. Thanks folks
