Good suggestions here. What speed sensor did you replace? If you pulled the speedometer gear recently then I'd just pop it out again and inspect the gear for damage. Like @Jerry Bransford says the gears are easily damaged.Just replace the speed sensors but no luck. Any ideas what it could be?
Hi all thanks again for all your suggestion. I think I found it. Chewed up gear and loose gear housing. Gear literally fell Off. New housing and new calibrated gear and I just drive 20 miles
Does a 2004 rubicon not use the gear? or is it an electronic sensor?
