I am having an issue with my 2002 Jeep Wrangler X, 6 cylinder, automatic transmission with 124,000 miles. On August 15, 2018 transmission cooling line starting leaking and had both replace and transmission fluid toped off. Since then my jeep has had an issue with stalling out sometimes after hitting the brakes hard it will stall out the next time I come to a stop light. It also sometimes will stall out going from part into reverse. These issues only started after replacing the cooling lines. Transmission shifts ok and the fluid was changed at 98142 miles but I noticed the old shop used Universal Syn ATF the fluid looks good.
I have had a computer diagnostic done by my mechanic with negative results. He also has cleaned the fuel injectors; the throttle body, the IAC and checked the plug gaps tested O2 sensors.
Any ideals?
Thanks
Any ideals?
Thanks
