2003 vapor leak detection pump
Ygeorgey
Lakeside,Ca
I am in the process of removing the vapor leak detection pump on my 2003 sport. According to the shop manual you remove three fasteners and disconnect two vapor line prior to removal. I removed the fasteners from the access plate and a 4th that appears to hold a frame to the welded part of the body. I disconnected a vapor line that goes from the tan to the assembly and have the following questions.
1. Where does the second vapor line connect and what color is it.
2. Does the vapor canister, pump and filter slide out as a one piece assembly?
The assembly has only moved 1/2 inch forward. Am I missing a fastener?
Pictures might help.
The factory service manuals are available in the Resources section for download and there should be a procedure for what you're trying to do.
-Mac
