- Price
- 8,000
- Location
- Ossipee Nh
2004 Jeep Wrangler Rocky Mountain edition . 5 spd 4.0L . Runs great . Shifts great . Newer clutch . No check engine lights . 188k Just came from a frame off rebuild ! Tons of new parts . Documentation of everything done by me (pics) . Everything listed is BRAND new parts - it has front Dana 30 & rear Dana 44 ( same as rubicon ) differentials , 4” suspension Lift ,flat paint ( soft iron metallic ) , 2k matte clear coat , hood decal,body decals , 5- rims/tires, 33x12.5x15” MT, passenger / driver side fenders,7” fender flares , tube rocker guards , adjustable trac bar ( front / back) , adjustable front lower control arms , upper control arms ,radiator , power steering pressure line w reservoir, smoked turn signals / parking lights ,matte black grill inserts , gas tank filler cover w lock , rubber filler neck , gas tank straps ,front hubs w wheel bearings & w new bolts , tie rod ends , passenger side upper / lower ball joints , hood latches , windshield bumpers , mirror relocation brackets ( door swap w ease ) , windshield frame, tailgate, reinforced spare tire carrier w greasable hinges , front / rear bumpers , tube half doors , Bimini top , full water proof cover , full stainless brake lines , greasable axle tube seals , full set of body mounts , full rear brakes ( hardware , pads , drum) , e brake cables ( center , left / right) dust shield covers , led headlights , fog lights, wipers , interior (tub)fully coated w bed liner , frame totally redone , underneath tub redone , fire wall painted , full exhaust from headers to tip ( flowmaster muffler sounds great ) ( everything painted w high temp paint ) Bluetooth cd radio , shorty radio antenna , 4- speakers , 1000watt amp , usb charger built in to dash , molded floor mats , stienjager stainless steel transfer case shift cable ( super smooth ) , 02 sensors , have full doors in great condition W new hardware but not finished yet( repainted to match ) ! 5 original 30”tires ( excellent condition) w Alcoa rims ( great for storage only ) soft top in great shape ! mobil 1 oil change , both differentials , transfer case , transmission , power steering fluid , brake fluid , coolant , all changed w 50miles ! just had inspection, alignment & ball joints done at shop ($500) soooo much much more , Seeing if it catches anyone’s attention! clean title in hand. Just some small things left to finish ! ( door hinge bushings , spare tire bumper , etc)
