- Price
- 18,000
- Location
- Crown Point, Indiana
Unfortunately I have come to the point that I no longer can drive my Lj. It’s time to let someone else get it out and enjoy it. The Jeep has had just about everything replaced, or rebuilt over the last year. Everything has less than 14K miles on it. The Jeep was professionally re painted over winter, I do custom and restoration work, this would have been a 10K paint job all day if you brought it to my shop. I had NO intention of ever selling this There was plenty of blood sweat and tears put into this thing. Although some of the things on this list are minor this is a list of everything that I have done to this since I purchased it.
Kc headlights
Kc spots
OEM Radiator
Upper/ lower hoses
Water pump
Thermostat
Belt
Plugs
Coil packs
IAC valve
Steering gear box red head
Intermediate shaft
Tie rods
Drag link
Pitman arm
Ball joints
Front/rear rotors
Pads
Front and rear true track differentials
4:88 revolution gears
All front and rear bearings on axels
Front outer axel seals
Front inner axel seals
Axel shaft u joints
Complete rebuilt tc case including chain
Zone 3” lift
Rancho 9000 shocks
Catalytic converters
Muffler and tail pipe
Motor mounts
Trans mounts
Battery
Trans filter and fluid
Best top NX
Door hinges
TNT rock sliders
Advanced adaptors SYE kit
Front driveshaft (Tom wood)
Rear driveshaft (Denny’s)
Front metal cloak track bar
Rear metal cloak track bar
All 8 metal cloak control arms
Metalcloak discos
Warn front diff guard
Air filter
Tb cleaned
Gas cap
Sway bar end links
Front sway bar frame bushings
Front axel housing bushings
Rear axel sway bar bushings
Rear sway bar end links
Front brake lines
Dirty Dog Cargo net
Rear reveloution chromoly axel shafts
DX4 wheels
33x12.50 15 BFG K02 less than 2000 miles
Steering dampener
Yukon 5x5.5 bolt free spin locking hub kit
Yukon 4340 inner front shafts
Curie front steering.
Borgeson upper steering shaft
Warn rear diff guard
Arb front bumper
Smittybuilt 10k x2o winch
Smittybuilt rear bumper and carrier
Led tail lights
Bosch 4 hole injectors
Fuel heat shields
Seat foams
Leather seat covers
Seat heaters
Stereo system
MetalCloak oil pan skid
Teraflex 3/4 spring spacer
Complete repaint 2/10/19 PPG base clear factory solar yellow.
Rt steering knuckle
Savvy Tc shift cable
Windshield
Windshield frame
Leather steering wheel
All door weather strips
Window belt moldings
Tail gate weatherstripping
OEM door handles
Head light rings
Tailgate OEM handle
Painted OEM Rubicon fender flares
OEM gas pocket
OEM park lights
OEM Side market lghts
Kc headlights
Kc spots
OEM Radiator
Upper/ lower hoses
Water pump
Thermostat
Belt
Plugs
Coil packs
IAC valve
Intermediate shaft
Tie rods
Drag link
Pitman arm
Ball joints
Front/rear rotors
Pads
Axel shaft u joints
Zone 3” lift
Rancho 9000 shocks
Motor mounts
Trans mounts
Battery
Best top NX
Door hinges
TNT rock sliders
Metalcloak discos
Air filter
Tb cleaned
Gas cap
Sway bar end links
Front brake lines
Dirty Dog Cargo net
DX4 wheels
Steering dampener
Arb front bumper
Led tail lights
Fuel heat shields
Seat foams
Leather seat covers
Seat heaters
Stereo system
Rt steering knuckle
Windshield
Windshield frame
OEM door handles
Head light rings
Tailgate OEM handle
OEM gas pocket
OEM park lights
