- Price
- $25,000 OBO
- Location
- Colorado Springs
For Sale - 2004 Built LJ
I have a 2004 LJ. It was bought as a Salvage vehicle due to a crinkle in the body that insurance said required a remove and replace of a body panel that is no longer available. There is a picture of the Jeep in the form it started in. Have a Colorado Title
I have decided to build a different project, so selling this one to fund the new one.
Since then, the Jeep was taken all the way down to the frame, and built back up.
Rokmen RokStar Mid Arm Suspension with OME HD Springs front and Rear - About 2.5" of lift
Dynatrac Pro Rock 60 Axles with 35 Spline ARB's - New November 2018 - Driven for the first time April 2019 - Less than 1500 miles.
GM LS 6.0 with built 4L60E Transmission - Novak Adapters Conversion Parts used - Novak Radiator, Novak Harness, Holley Mid Mount Accessories.
Atlas 4-Speed Transfer Case - 1350 rear flange, 1310 front u-joint
Tom Woods Custom Driveshafts - Front less than 1 month old
Hydroboost Brakes
PSC Power Steering components, ready for Hydraulic Assist if desired.
Custom Roll Cage using 2" DOM .120 wall in all areas except for the outer header bars over the doors so that the factory surrounds fit, and across the dash just for visibility.
37 x 12.50 x 17 tires on steel wheels with 8x6.5 bolt pattern.
Poision Spyder Customs Armor all powdercoated yellow.
A lot more things as well that are too much to list here.
Also willing to part the Jeep out if the price is right for the components.
Hydroboost Brakes
