- Price
- $17,500 OBO
- Location
- Raleigh NC
SOLD!! Let it go for $15,750 to a 22 yo kid who could barely contain himself
2004 Jeep Wrangler TJ Unlimited, 122,000 miles.
The ONLY reason I am selling this is because I have the opportunity to move on to a bigger rig for the off roading that I want to do.
This Jeep is extremely capable off road and also good as a daily driver. I have run Dickey Bell, Dutch John and the backside of Daniel at Uwharie National Forest with ease in this Jeep.
It is nimble on the trails and drives straight as an arrow on the street. It will cruise at 75MPH at around 2700RPMs all day long on the highway. Take the top and doors off and it is the most fun you can have with your clothes on.
In some ways it’s hard to part with it but it is time to move on.
The engine has just been replaced and I am just rolling the first 1,000 miles on it. A break-in period was done on the engine: at 250 miles the filter was changed and then at 550 miles the oil and filter were changed. During that 550 miles the engine was run through various RPM ranges and never left to sit at one RPM for lengths of time (i.e. no cruise control down the highway). The engine idles smooth and performs strong. It is an ATK remanufactured engine complete with a 3 year unlimited mileage warranty. Yes, I said three years.
The engine, parts and install alone cost $4000.
All of the specs are down below. It has a factory hardtop even though it started its life as a soft top. I also have a Besttop bikini top and Besttop Jeep cover for when the top and doors are off.
I also have a set of brand new Black Magic brake pads for the front still in the box as well as many extra Fel-Pro gaskets and the factory stereo.
Lastly, I have a 3-ring binder that contains all paperwork of everything done to the Jeep.
The pictures you see are from various stages of its life so, for instance, there may be no winch in the pic but there is one on it now.
Parts replaced during engine install:
OPDA unit and sensor
Throttle position sensor
Air idle control sensor
Oil pressure sensor
Upper/lower radiator hoses
Water pump
Water pump down pipe
Thermostat
Harmonic balancer
Serpentine belt
Fan clutch
Transmission cooler lines
Transmission flex plate (also known as a fly wheel on stick transmissions)
Mopar coolant used
Mopar oil filters always used
Valvoline NON SYNTHETIC oil used
Axles:
-2005 Rubicon Dana 44 Front and Rear Axles
-4.88 Yukon Gears
-Eaton E-Locker (Front)
-Chromoly Axle Shafts (Rear)
Suspension: 2” DPG Offroad TJ Super Ultimate Lift, contains the following:
-JKS J-Flex Adjustable Control Arms (all eight of them)
-Old Man Emu Springs
-Old Man Emu Shocks
-Old Man Emu Steering Stabilizer
-JKS Sway Bar Disconnects
-JKS Front and Rear Adjustable Track Bars
-Synergy Ball Joints
-1.25" JKS Body Lift
-+1" Brown Dog Motor Mounts
Exterior Mods:
-MBRP Exhaust
-Black Magic Brakes/Rotors Front and Rear
-Adams Driveshaft (Front)
-Novak Cable Transfer Case Shifter
-LOD side step/rock rails
-Level 8 Tracker 15x8 Aluminum Wheels x5
-33x10.5x15 BFG KO2 Tires x5 – still have the little rubber nipples on them.
-Barricade Front Bumper w/ LED Fog Lights
-RC 9,500lb winch with synthetic line
-Skid Row Transmission/Oil Pan Skid Plate
-EAG Rear Bumper
-LED Headlights
-Zone steering box skid
Interior:
-Bedrug floor liner (Front, Rear and cargo area)
-Husky Cargo Mat
-Quadratec Front Mats
- 1.25” Seat Riser Pucks
- Pioneer stereo unit with USB, AUX, Bluetooth, Spotify and Sirius XM
- Kicker speakers
- Factory sub-woofer replaced with Quadratec sub-woofer speaker
Maintenance at 109,000 miles:
-U-joints in all axle shafts replaced
-Rear drive shaft universals replaced
-PCV Valves Replaced
-Parking Brake Shoes
*** During the first 5,000 miles you CAN NOT use synthetic oil as the engine is still considered to be in a break in phase. After that you can use what you want. Personally, I would stick with traditional oil. The 4.0L straight six engine is bullet proof and when designed standard oil was used. I’m of the mindset to keep with regular oil on these engines since synthetic really doesn’t have an advantage in these, plus it’s more expensive. It is not uncommon to see a well maintained 4.0L engine go above 300k miles.
With all the work and build done to this Jeep it’s well into the mid $20,000 range which I know I will never get for it. Asking $17,500 OBO
Oil pressure sensor
Water pump
Thermostat
Harmonic balancer
Serpentine belt
Fan clutch
Mopar coolant used
Axles:
-4.88 Yukon Gears
-Old Man Emu Shocks
Exterior Mods:
-MBRP Exhaust
-EAG Rear Bumper
-LED Headlights
Interior:
-Husky Cargo Mat
- Kicker speakers
