Hello all. I'm at a hair pulling moment. I am suffering from low heat in the 2004 LJ.
So far to date and for some other reasons than lack of heat, I have replaced, the heater core twice, the water pump and 195 deg non fail safe thermostat, a radiator, all of the hoses (radiator and heater hoses). Last night was a heat/ac control panel, rechecked the blend door for free movement and also the blend door actuator for operation. Everything in the system has been replaced. To note I have also checked the fluid level and its full, I have checked and rechecked the floor vent and cowl vent actuator and I am stumped.
I get luke warm heat and its about 10 deg. here in Indiana.
I have also checked the temp of the hoses in and out of the heater core and at Idle its about 150-155 deg. (going from memory on this and I'm old so I might be wrong). It does rise in temp following throttle position. The same goes inside at the vents. At Idle its almost cold and does raise with revving up the eng.
Trying to think of other details.
With the fan speed set at low the temp is hotter and when on high it goes down, like the air volume is diluting the little bit of heat that is being put off from the heater core.
So yeah, I'm open for ideas!!!
