TJ Fest 2021
2004 Rubicon 4.0L Running Cool
Tux
New Mexico
As opposed to everything I have been able to find here and on Google, my TJ is running too cool, not overheating. 2004 Rubicon TJ, 4.0L, manual trans, purchased new in '04. Hit 65K miles and decided to do some preventive maintenance. Drained coolant, replaced all hoses, pump and thermostat (Super Stant 195°) refilled coolant with Zerex G-05. Temp gauge always used to point due north at 210°. Now it points about 3/16" to the left (low) of 210°, probably around 175° to 180°. Engine seems to be running fine but haven't driven it enough to determine if gas mileage has gone down. Just to be sure I didn't get a defective thermostat, replaced it a second time with another identical Stant 45359. Still running cool. I do detect a faint odor of unburnt fuel when I park it in the garage, as though the engine is running too rich.
Tux
Tux
New Mexico
Solved part of my problem. Found out my Torque Pro app can provide realtime data while driving so plugged in the OBDII blue-tooth scan tool and connected to my smart phone and went for a drive. The temp gauge is indicating about 170° but the scan tool is registering 203° once the engine is warmed up. So the problem is the gauge, not the engine. Next step is to reset the ECU and see if that corrects the gauge problem.
Chris
Administrator
Staff Member
Florence, AZ
I was literally just about to respond and say that it’s likely the gauge, not the engine. Glad you got it figured out, and thanks for the update!
Goatman
TJ Expert
Upstate NY
Check the sending unit. It is likley to be the problem more than the gauge. Also much cheaper and easier to change out.
Jerry Bransford
TJ Guru Moderator
Staff Member
Escondido California
X2, the coolant temperature sender is mounted adjacent to the thermostat housing. Swapping it is a quick job. Maybe related to having been working on the thermostat housing next to it.
Tux
Tux
New Mexico
Failed to mention that I replaced the sending unit with a brand new one. Again, real time OBDII info indicates 203° while gauge only indicates 170°.
TJ4Jim
Lifetime Supporting Member
Brookings, Oregon
Did you use a Mopar sensor, most of the aftermarket ones are crap.
