I’m having an issue with my 2004 TJ, Manual Trans 4.0. The Jeep sat for about a year(Needed a clutch and a few other things) and when I test drove it around the block, it felt like it had a Miss but had no codes. I figured I would try changing the plugs. I changed the plugs and now it idles good but once I go beyond 2000 rpm's, the engine sputters and the CEL Light comes on and throws the P0351, P0352 and P0353 or a combination of at least 2 of them.
I’m on my 3rd set of plugs, I’ve tried 3 different Coil Packs, I have now sent the PCM off to get checked. It checks out as Good. I’ve changed the Coil Pack Connecter, I’ve Changed the Fuel Injectors, Battery is Charged. The TJ has Fresh Fuel. Does anyone have ANY Idea what the issue might be?
I’m wondering if anyone else has run into this issue and how you resolved the issue. Please let me know. Thanks.
