I have a 04 wrangler sport 4.0 That I’ve now been 2 months trying to fix below is a list of things I’ve done any advice is greatly appreciated.
Crank sensor From Mopar
Ignition coil rail-Bwd
Spark plugs-xp985
Fuel pump
Cam sensor-drive works
Multifunction Switch connector
PCM-Repaird by Neat Computers
New Optima Battery
IAC valve
Throttle Position sensor -bwd
Actuator pin
Ignition switch
4 hole injectors
That’s all I can think of right now but it doesn’t seem to be gettin power to the coil once again thanks for any input
Spark plugs-xp985
Fuel pump
New Optima Battery
IAC valve
Actuator pin
Ignition switch
4 hole injectors
