maybe someone else will jump in here.I don’t believe so. Not easily anyways. The evap lines connect differently for one. I’m not sure my fuel pump would be retained the same in an ‘04 tank either…
I know you have to modify an ‘05 pump to fit an ‘04 tank. But yes, the evap lines are different.I don’t believe so. Not easily anyways. The evap lines connect differently for one. I’m not sure my fuel pump would be retained the same in an ‘04 tank either…
That was me. You just have to mill down the diameter of the top just a bit to drop it in. Post 1,261 over in my build thread.maybe someone else will jump in here.
i thought i remember somebody using the 05-06 pump in a previous yr clamp ring but don't recall the details. the evap is just tubes and can be routed as you need.
How are all the connections? Anything broken? That’s my current issue. Cracked fittings at 3 connection points…I have one I pulled from my 05 LJ to install my Genright tank. I’m in Dayton about 3 hrs away.
It is currently being stored in my garage attic. Everything was in good working order when I put it up there. My LJ had 71k on it when I removed it.How are all the connections? Anything broken? That’s my current issue. Cracked fittings at 3 connection points…
