- Price
- 9100
- Location
- Manalapan, NJ
VIN: 1J4FA69S95P330257, clean with no accidents. Owned since August.
(Not sure how many owners so if someone pulls the car fax please share)
Facts:
- 135K miles
- 6 Speed Manual
- Cold AC
- Factory Sunrider Soft-top with tints. One side window (driver side) has a slit.
- Goodyear Wrangler Duratracs 31” with decent tread. Unlimited wheels in OK condition. I have 3 spares.
- New rear brakes (rotors/pads) and parking brake
- New exhaust system (Pre-Cats and Main Cat Converter) with Borla Catback
- 2.5 inch Rough Country X-series with adjustable Control Arms, Springs, Shocks, drop link quick disconnects. The drop links are shot, but I have Factory replacements
- New Felpro Valve Cover Gasket
- Factory 44’s and Lockers 4.10’s and NV241OR Rocktrac
- Factory Fog Lights. Have a crack on one of them
- Upgraded stereo w/ Bluetooth
My comments:
- Engine/trans/t-case/lockers: no dash lights. Runs really nice and shifts smooth, lockers will blink on the dash for a bit then lock in if you rock her back and forth. It did leak around the oil pan when I bought. After fixing the valve cover, leak seems to have mostly stopped. I still get a spot or two on the driveway after running it.
- Frame is a northeast frame. It’s in ok shape and does have surface rust. Probably could use POR-15 and a top coat. I dropped the skid plate to install the new exhaust and the bolts came out and went back in fine.
- Body: Generally good. Underneath you will see surface rust at the back rockers, but I put my finger in and doesn’t seem to be rusty inside. Under the drivers mat there is some soft metal that could use attention. Hood has dents in the normal place.
Reason I’m selling is because I found an unlimited rubicon (profile pic), I don’t drive it much and I need to recoup money.
Let me know what you think about it.
Mark PM or 3476203075 - leave a text as I’m traveling out of the country at the moment.
Facts:
- 135K miles
- 6 Speed Manual
- Cold AC
My comments:
