Minnesota 2005 LJ Rubicon *newly detailed*
dylansalrin
Orthopedic Circulator
Minneapolis, MN
Price
17000
Minneapolis, MN
Newly detailed 10/13/19
This is a 2005 Jeep Wrangler Unlimited Rubicon, also known as an LJ, LJR, TJU etc...
I flew to Oregon in 2018 to get this Jeep. This jeep has zero rust on the body and frame is clean as a 2005 can be. It has been stored for all the winters it spent in the rust belt. Never driven when salt existed on the roads. These models are not your typical Jeep and were made only between mid-2004 to 2006. This rubicon model was the most expensive; highest package you could buy in its time.
Miles will slowly go up as this is my DD.
This has been the best vehicle I have ever owned. I have never had an issue with it since I've owned it for almost two years now. It has never had any check lights on and has not skipped a beat. This was going to be my forever car so I took care of it religiously. Put around 14k miles on since owned. The title is clean and in hand (paid off). Has all the options available plus some.
The Jeep was relatively stock when I bought it. I have since added quality parts that are listed below:
Poison Spyder front "stinger style" bumper $425.99 (plus cost of licence and mouting plate brackets)
12,500 lb capacity winch with newly installed synthetic line $455.69
UV resistant winch cover $59.99
Offroad winch shackle $151.00
Grille insert guards $29.99
DOT-approved LED headlights $351.00
JK style grille turn signals $109.99
HD steering kit (drag link and tie rod from 1 ton ZJ) $194.99
New Steering dampener $49.00
Front and rear hi-cut fenders $435.67
Premium Bestop soft top with tinted windows and "sunrider" flip top function $1,099.99
Rear LED brake lights $99.99
OR-Fab heavy duty swing out tire carrier $549.99
315/75r16 Maxxis Big Horn MT tires (rotated with spare every 6,000 miles) $1,140
Motor mount lift $54.95
1.25" body lift $128.99
2" coil lift kit with shocks $229.95
Replaced transmission and engine skid plate (factory option).
Wrap around jeep net enclosure $335.95
Sun shade UV cover for LJ $59.99
Net divider front and rear seats $89.99
Rear seat still installed with flip and stow function
Weather-tech floor mats $127.95
Factory styled touch screen stereo with android OS $319.99
Front dash cam integrated into rear view mirror with screen $59.99
Phone/cup mount $19.95
Soft doors (lower half and upper half included!) $553.99
Tow package (hitch assembly and wiring) $107.83
SWAG offroad swing down tailgate kit $214.95
Instatrunk security box $156.99
Kicker subwoofer replacement $26.98
Hubcentric SpiderTrax spacers $109.00
Regear differentials to get power back after large tires. 5.13 Revolution gears $2399.00
Side turn signal relocation kit $39.99
Hood pin install $42.00
Engine block heater (winter package) $104.99
New oil change 7/21 (Oil changed every 3,000 miles)
New Coolant/flush 5/1
Differential Oil changed 4/25 (gaskets also new).
New Crown OPDA September 2018
New brake pads 5/1
New Battery (and terminals) 5/1
New wipers 5/1
Tires currently have 7,100 miles on them. New in April 2019.
New Sway bar links 7/21 Read Less
Reactions: BoundlessBasu
dylansalrin
dylansalrin
Minneapolis, MN
In your opinion am I too high in price? What do you guys think is fair to ask?
army_greywolf
Slinger WI
I'm a forum newb but not to jeeps. A quick look see on facebook marketplace I found four TJ rubicons under 11. Obviously can't vouch for parts on those but some research and adjustment is probably going to be in order.
dylansalrin
dylansalrin
Minneapolis, MN
Have you thought about paying a professional detail shop to try and remove all the old black paint?
Got an appointment scheduled for next Sunday to get it all off for good. Hopefully that helps the sale. Been posted for two weeks now with no interest. Didn’t think I was insanely high
Reactions: Starrs
taylormade73
Ohio
This is an LJ Rubicon not TJ, which is a bit rarer. Good ones are 15kplus up to 22k plus for low mileage ones.
Bradb0816
Conway, AR
I will be honest...even after that detail job, I still think this is still high. The body is in rough shape (I thought they might get the black off in the detail job) compared to other ones I have seen. Plus, even though it may have been stored in winters, it is still a northern Jeep. If the body was in better condition and it was from down south....I might pay 17k. Just my honest opinion.
Alex01
Enthusiast
Martinez, CA, USA
17k seems like a fair asking price but my guess is you'll get somewhere around 15k for it. Lower the add to 16,950 in the meantime. It looks better than 17K.
Wrap it, it would be a much easier sell with either a new paint job or a wrap.
Chris when did you start working at a used car lot. :ROFLMAO: Can you imagine peeling off the wrap to find that paint? Talk about a terrible Christmas Morning.
If you don't mind doing some labor and prep work it looks like a good candidate for a maaco paint job.
Reactions: Starrs
Chris
Administrator
Staff Member
Salem, Oregon
True, but I've seen some amazing wraps that look even better than factory paint!
Alex01
Enthusiast
Martinez, CA, USA
I don't doubt that. But, personally I wouldn't feel right about selling it without disclosing the issue that is underneath. Which would then pose the question of... Would it still need to be sold at a discounted rate?
Reactions: Starrs
Chris
Administrator
Staff Member
Salem, Oregon
No, I just meant wrap it so it looks good, but don't take down the photos of what it looks like underneath.
I'm not suggesting he hide the original photos, just make it look better so it's more appealing to a prospective buyer, that's all.
Reactions: Alex01
