Back with more, and I have lots of pictures for you all! Got lots of work done last night and tried to document my process best I could.
Here's what I started with vs. what I ended with last night.
Amazing how much wire is in these harnesses. I also have a ton of extra plugs and wires now if anyone needs any.
As for my process, I'll explain how to read and de-pin wires from the harness in order to remove a plug. The wires go all over the place, so it'll be up to you to find where they go using diagrams. Once you've figured out wiring paths based off of the wiring diagrams, you can begin.
I'll start with the Manifold Absolute Pressure (MAP) sensor. I wanted to remove the wiring from the harness and pull the plug out in one fell swoop. Going through the FSM and picking the pinout connector, I found the shape of the plug and the corresponding wires.
We see three wires with specific colors; VT/BR (Violet with a Brown stripe or "tracer") which is the MAP Signal, DB/DG (Dark Blue with a Dark Green tracer) which is Sensor Ground, and YL/PK (Yellow with a Pink tracer) which is 5 Volt Supply. If we look through our FSM we see that all of these wires end up at the PCM plug. The 5 Volt Supply and Sensor Ground are shared by several sensors through various splices. Focusing on the wire specific to the MAP (VT/BR), I used the PCM pinout to figure out it's location in the 38-cavity plug. There are duplicates of colored wires used throughout the vehicle, so there's a special code given to a wire so a user isn't confused. You'll see "K1" circled in red on each connector description. That's a foolproof way of knowing this is referring to the same feed of wire. We can see the same code here.
The number "23" represents the wiring cavity in the PCM plug. Each PCM plug has 38 total possible cavities for wiring. I need to remove the VT/BR wire from cavity 23 to free up the first wire on my MAP sensor.
To open up the PCM plug, start by removing the back cover from the plug. Insert a little screwdriver into the slots circled in yellow on each side and pop the cap off.
Once off, slide it down the wiring a few inches to give yourself room to work. The white piece is a grommet to keep moisture out, remove this too.
Next focus on the front. Push in on the little tabs on each side circled in yellow and the front cover should pop off, exposing the pins.
Once removed, start locating the wiring you need to remove using your FSM. Cavity 23 finds me with a VT/BR wire which is our MAP Signal, ripe for removal.
Once removed, I pulled it back through the harness to the MAP sensor. First wire is unhooked! Next we'll move to Sensor Ground which is DB/DG. This wire shares several splices with other sensors, so I opted to just cut it coming from the connector at the first splice.
Lastly, I moved to my final wire; the YL/PK wire for 5 Volt Supply. This wires shares the same sensors as the DB/DG wire did, so I did the same thing by cutting the wire at the first splice. You can see the splice tucked under a few wires.
With all three wires free, I was able to remove the plug entirely from the harness and coil it up off to the side.
As another example, I used the same method with the Throttle Position Sensor (TPS). I located the wiring I needed and began the removal process.
I found my PK/YL wire and removed it. This is another 5 Volt Supply with multiple splices, but I opted to remove this wire from the PCM plug first using the pinout chart to find the right cavity.
Wire at the splice. I snipped the wire coming from the TPS connector at the splice.
I did the same with my shared DB/DG Sensor Ground and snipped the wire coming from the connector at the splice.
Then lastly I removed the BW/OR (K22) wire from cavity 21 in the PCM connector.
With all three wires free, I pulled the connector out and coiled up the wiring off to the side like I did with the MAP connector.
As you work, you'll be left with a jumbled mess like this, but don't worry. As you move along, the wires start to disappear and everything makes more sense.
This is the process that I used to remove all of the driver side sensors for the engine. I now have a somewhat neat pile of very much intact wires and sensor plugs that I can use for other things in the future.
There are still a few sensors left on the passenger side of the engine that need to go away, like CKP, CPS, Coil Rail etc. These share the same leg as the transmission wiring, so I decided to wait until tonight to knock them out. Removing everything on the driver side seemed like a good start and helped me make some major headway in reducing the size of this harness.
I'll try to update tomorrow or Saturday with my progress!
