SOLD 2005 TJ Wrangler X 6 Speed $14,000
k-huevo
Houston
Price
$14,000
Houston, Texas
Wrangler TJ X 2005, 28322 miles, Patriot Blue, 6 speed. In overall good condition with no rust-through spots on the frame or body. Currently riding on 31X10.5X15 tires and has clearance for 33s. Paint condition is fair but has many scratches and small dents. There is a rock crease/dent, in the left side rocker panel. No rear seats. Full Dynamat coverage on the tub. The canvas top is in fair condition, although the zipper on the left side of the rear window flap only unzips to a point about 2/3rds upward. The transmission was replaced at about the 20k mile mark, after losing reverse gear. Here is a list of most of the aftermarket modifications:
AccuTune Fox 2.0 shocks
Currie front and rear Trac bars
Currie Currectlync steering kit
Currie front Antirock swaybar (different diameter bar included)
Savvy upper control arms front & rear, Savvy front lower control arms, Hybrid Savvy/Synergy rear lower control arms
Currie 3 inch coil springs, CE-9133F, CE-9133RH
Savvy transfer case shifter
Slip Yoke Eliminator
High Angle Driveline drive shaft
1 inch engine lift
.5 inch body lift
Aluminum tummy tuck
B&M short shift mechanism and shifter
Flowmaster exhaust
Also included with the TJ are many extras: currie JJ tools, tow hitch bracket, stock front swaybar, aftermarket swaybar, stock rear trac bars, Synergy bushings, spring spacers, extra exhaust tip & tube, and lots of miscellaneous doo-dads.
Reactions: PRNDL
