I have a 2006 Wrangler and have been experiencing some stalling issue when decelerating. A few days ago the check engine light came on. I checked the diagnostic codes and codes said a mis-fire on cylinder 2 and bad O2 sensor at catalytic converter. The converter was also getting hot and the engine started missing really bad. I found an issue with the spark plug cable on cylinder 2 and have replaced all 4 cables and all 4 plugs. The plugs that I removed were light brown to white in color with some darker discoloration on the plug from cylinder 2. I checked the diagnostic codes again and the mis-fire code was no longer present. The O2 sensor was still present. I replaced the O2 sensor and the missing improved...meaning not near as bad and the engine feels like it has a bit more power now but the catalytic converter is still getting hot and the miss is still present. At the tailpipe it sounds like a puffing noise and there is a slight smell of gas if you put your hand in front of the tailpipe. Any ideas?
