After going thru this UCF process....I couldn't help but think maybe the Genright weld in mount and a removable skid might have been a better set up.Look at that non-shovel! My dropped TC is jealous.
@Starrs went and sold his Rubi with my 35's still on it....the nerve!Looks awesome! I’m just thinking it’s time for 35s?
I'm running that same light combo, and it's so much better than stock. Did you upgrade your wiring and relays too?After reading the headlight upgrade threads I finally decided to put Cibie reflectors in with Phillips extreme halogen bulbs. (I'm not big on cheap chinese LED's) Was originally going to use the Hellas but read where the Cibies outperformed them.
Cibie 82440 housing:
https://www.amazon.com/gp/product/B008DQV88Q/?tag=wranglerorg-20
Phillips 130% Extreme halogens:
https://www.amazon.com/gp/product/B00NMEEOV2/?tag=wranglerorg-20
Kind of a lame picture passenger side Cibie, driver side stock. Cibie much whiter. A vast improvement as all have said:
PS: Dont hate on my Factor 55 bling. (Bought before I realized it wasn't TJ Forum approved)
Just to clarify, you went with their highest, lowest profile option right? I was looking at their middle option of the 3 because I dont have the ability to modify things like you have had to on your install. The middle option should have enough clearance to bolt right up without cutting and welding?
I went with the highest / low profile one.
I believe their middle model uses UCF's lo-pro mount if I recall so there would probably be the same mod process involved.
I milled mine but a grinder would sure work.
I did the middle option, no cutting or welding needed with the 241. Needed a cable shifter, adjustable rear upper CAs, and a new drive shaft. Did have to trim the rear spring perches after rotating the pinion up. Had 2.5 SL, 1.25 BL, and 1" MML installed prior. Needed the BL for sure. Used oem trans mountJust to clarify, you went with their highest, lowest profile option right? I was looking at their middle option of the 3 because I dont have the ability to modify things like you have had to on your install. The middle option should have enough clearance to bolt right up without cutting and welding?
