So the build pile continued to grow in the last few weeks:
MetalCloak double adjustable aluminum control arms (thanks!
@Chris)
JKS JSPEC 3" springs
JKS Front & Rear track bars
JKS Rear sway bar links
Rancho 5000X Shocks
UCF Aluminum winch plate
Finally had enough and being that its 49º and windy out decided it was time to start.
Mainly dirty tear down work this weekend. As a midwest jeep, I've got some areas to wire wheel and POR15 before continuing.
Also tossed out the transfer case shifter and installed a Savvy cable conversion. (thanks
@JMT for his write up on the install)
Have MORE motor mount lifts to put on.
Got the MC control arms mounted. (After spinning all the joints out and coating with anti seize) Probably going to go thru a whole bottle by the time the build is done.
And one other sonofabitch...one of the rear shock bolts decided to break, (we soaked everything with Kriol whenever we had the jeep on the hoist lets say since April) even after heating. What a shit design. Will probably tuck another weld nut in there and use anti seize liberally. At least with the body lift and the gas tank out you can access it.
Pic descriptions below:
Started with the body lift naturally the right rear weld nut came loose inside. We cut an access and welded it back in place. Otherwise went pretty smooth. Jr below welding the nut back in position:
View attachment 60587 View attachment 60588
Using a jack stand along with the hoist to raise the body off the frame to install the pucks:
Pile of dirt in the "mud scoop" This particular variety came from my one and only trip to the Badlands at Attica this spring. (
@IPerkWVU We'll bring it back on the next trip when we shake down the build!)
Woo Hoo! My lucky day.....dug thru the drill collection and found an extra long 33/64 drill....just what the DR. ordered to drill the mounts for the larger bolts on the MC control arms:
View attachment 60591 View attachment 60592
Dropped the gas tank and while it was down removed the back flow? valve. Filed the little ribs on the float and now it doesn't stick. (and hopefully doesn't spew gas anymore)
Jr. tightening the tank straps in the UCF skid. This will allow the tank to come up 1". We had to SOAP the tank and skid to get the tank in. Very snug fit.
