Finally got it out for a test drive!
It does have vibration just off idle emanating from the UCF Lo-Pro mount which by its design is understandable as it more or less boils down to 2 plates of steel with a 3/16 rubber pad sandwiched between. It does have the bushings off to the side to handle the torque. At cruise its not noticeable. The trade off might be worth it for the clearance.
The "throaty" MBRP exhaust sounds great. Mainly just at low RPMS do you hear it. Nice size muffler for the crowded underside rear of LJ.
Re-set the toe-in and re-centered the steering wheel.
Rides much better than it did on the stock (200K) springs that were in it. Not harsh at all. (But I'm used to a 3/4 ton truck)
Anti-Rock set on medium hole definitely has more body roll.
Stock driveshafts. Slightly tilted my rear pinion upward with no perceptible vibration.
No interference with the gearshift in the stock location.
It's sitting 5 3/4" higher than when I started.
Re-cap:
1.25" Savvy BL
1" MORE MML
3" JSPEC progressive springs
Metal Cloak DA Aluminum control arms (thanks
@Chris)
Anti-Rock Front
Rancho 5000X (for 2.5" lift...thanks guys! yes they run long!)
33" BFG KM2 (thanks
@Starrs)
UCF Ultra high skid, Lo Pro trans mount, and UCF Aluminum 1" rise gas tank skid
Savvy cable transfer case shifter
Olympic rear bumper w/hitch
YJ front brake lines
Powerstop brakes
To Do List:
Mount the winch
Cooling system OH
Spark plugs
O2 sensor gremlins
Valve cover gasket
Spark plugs
ZL steering
View attachment 62152 View attachment 62153
