Man, all you guys with TT are making me jealous. @Farmergreg @IPerkWVU . How beneficial has it been for you to be tucked?
I did. It allows full voltage to the headlights to make them as bright as possible. Check out Danielsternlighting.com for the details, but the short version is you create a new harness for your headlights, and use the existing harness to trigger two new relays. The new harness is heavier Gage wire, direct to the battery, so you minimize voltage drop.I did not....is it a good idea?
Haven’t gotten to get off road since the install, trip got rained out a few weeks ago. There is a particular rock at Badlands that I got hung up on last time out, that is going to be the test next time I’m there.Man, all you guys with TT are making me jealous. @Farmergreg @IPerkWVU . How beneficial has it been for you to be tucked?
I did the middle option, no cutting or welding needed with the 241. Needed a cable shifter, adjustable rear upper CAs, and a new drive shaft. Did have to trim the rear spring perches after rotating the pinion up. Had 2.5 SL, 1.25 BL, and 1" MML installed prior. Needed the BL for sure. Used oem trans mount
I am tempted to go this way for ease of install and still 2.5” over stockHaven’t gotten to get off road since the install, trip got rained out a few weeks ago. There is a particular rock at Badlands that I got hung up on last time out, that is going to be the test next time I’m there.
Man, all you guys with TT are making me jealous. @Farmergreg@IPerkWVU . How beneficial has it been for you to be tucked?
I really like that wheel/tire combo. I would go as far as to say it’s perfect haha.
That was the best one! LolIf only I had got the spare.......
And some nameless S.O.B is out driving around with it!That was the best one! Lol
I thought I was seeing double for a minute here. You and @ac_. Whose next?Last Sunday fooling around at the Badlands ORV park, I pulled an @ac_ and bent my passenger lower control arm bracket toward the drivers side. Maybe the tire slipped off a rock? Flimsy azzed sheet metal crap.
So I ordered some Arctec LCA brackets and installed them.
Bent original bracket with control arm loose hanging from the top:
Beefy Arctec bracket installed:
And painted:
On the bright side it seems to be a weakness issue that has several aftermarket solutions. Mini skids before I bent it would have been easier than cutting and grinding off the original bracket.I thought I was seeing double for a minute here. You and @ac_. Whose next?
Smart advice! After the Moab trip I'll be giving a good looking over and changing fluids, checking brake pads, etc....On the bright side it seems to be a weakness issue that has several aftermarket solutions. Mini skids before I bent it would have been easier than cutting and grinding off the original bracket.
This was the first time I've had it on the hoist since November when I finished the lift and control arms. Wanted to give it a good looking over and make sure everything was tight, etc..
Found a couple jamb nuts on the control arms that were loose, oil pan skid missing 1 bolt, and the bent bracket.
So check your rigs over!
