- Joined
- Apr 28, 2016
- Messages
- 6
Ok, I have a bit of a mystery on my hands. I have a 2006 wrangler unlimited with the 4.0. Problem started when the "rev limiter" kicked in at 3500 rpm. Did some work. Changed plugs, coil pack, crank position sensor, cam position sensor, then finally OPDA. This is my second replacement OPDA - the original one went bad about 6 months ago - bad bearing. Still having "rev limiter" issue at 3500 RPM, and it is giving the same code it did before - cam position sensor. Also, cruise control won't work after about 2 minutes of the Jeep running. One thing to note, when I pulled the second OPDA out, the gear teeth were worn, and that OPDA had a lot of play and rough spots in it when I spun it - I exchanged it for a new one because it was still under warranty. I have about 130,000 miles on the jeep.... ANY suggestions are helpful!!! Could it be the cam itself?
