T-Shirts
Order your offical Jeep Wrangler TJ Forum t-shirt today!
Click here to order!
Jeep Wrangler TJ Forum T-Shirts
2006 seat replacement
Ct jeepfamily
CT
The drivers seat has lost its firmness, questions - if I replace them the latch to flip forward is next to the head rest. How is this handled on the replacement ? Second recommendation for new seats that won’t break the bank.
Thanks
Jerry Bransford
TJ Guru Moderator
Staff Member
Escondido California
The seat base is separate from the seat and it's the base that provides the slide and tip forward functions. My PRP seats just bolted onto the bases.
TJ Jim
Tennessee
Bestop.
TJ Jim
Tennessee
They are one year old, and holding up great so far. So much better than the 16 year olds that came out. Yea I ordered the seat mounts 😪. I drive it about 10,000 miles a year. I tried to get the old ones redone but they wanted $1500 for that. For the flip seat I added a clamp with a four inch 1/4-20 bolt under it. Works great.
Jerry Bransford
TJ Guru Moderator
Staff Member
I have also been looking at new seats. Specifically the bestops and corbeau seats. How have the bestops held up over time? Did you have to get the seat adapter brackets? I have a 2003 and am looking for both front seats and also rear bench.
Avoid the Bestop Trailmax seat, it doesn't hold up. They replaced my driver's side seat twice under warranty and even the third seat's bolstering started collapsing like the first two did. I ended up with PRP seats which are doing great after 8 years.
AjRagno
MN
Thanks
Reach under the seat from the front and twist the rod that runs between the side brackets. The seat should fold and tumble.
