Hi everyone, this is my first post. This forum has been the source of all the info I’ve needed to repair this thing until now. Im stumped.
I have a 2006 TJ 4.0 M/T. I drove it the other day, parked and it has never started again.
When I turn the key to start I have all the lights and radio but nothing from the starter. All the lights on the dash work accept I have no reading from the fuel or voltage gauge.
I have replaced so far. Starter, starter relay, ignition switch, bypass clutch switch, checked ignition pin & tumbler(not broken).
I checked and get no voltage down the small starter solenoid wire. I jumped the started to get it to spin the crank with the key in but won’t start.
Also put the code reader on it and it says connection error.
Is this a PCM issue? I have had someone try and start it while I wiggled every plug I could find and still nothing.
Would you get this sudden of a failure. Most everything I’ve read shows intermittent issues before complete failure.
