2006 TJ Sport Build
tjroughrider
Winnipeg, Manitoba, Canada
I bought my TJ approx 5 years ago with 41,000 kms on it for $13,500 (cdn) which I figure was a great deal. With the purchase I had an alarm/command start installed (with the cold winters we have here in Winnipeg it is definitely needed).
The first year was a slow start to upgrades and I installed a cobra CB radio with Bluetooth and later I mounted a GoPro 3 Silver edition to catch all those butt clenching moments.
The second year was the upgrade year but only after going out on a trail run dubbed as Mudders Day. The group that I went on the trail run, ended up being stuck on the trail until 9:30 pm. From this day I went online to find the upgrades I wanted on my rig.
Upgrades:
  • Bushwacker 4" fender flares
  • JKS Quick Disconnects
  • Hi-Line Rockers
  • Zone 4" lift with nitrous shocks
  • Rampage front bumper with 4" driving lights
  • Rampage rear bumper tire carrier with 4" driving lights hooked-up to reverse lights
  • Rampage bowless soft top
  • Engo 10,000 Lb winch
  • Goodyear 33" x 12.5" x 15" tires
  • Granite Alloy 10.5" x 15" wheels
  • Genright removable mudflaps
Custom Upgrades/Fabs:
  • Tail light upgrade to 4" flush mount
  • Custom mirror relocation brackets
  • Upgrade to 160 Amp Dodge Durango alternator
  • Custom Hi-Lift jack mount
  • Custom hi mount brake lights
  • License plate relocated
  • Custom front skid plate
And more upgrades:
  • Rigid Pods
  • 4.88 gears front & rear
  • JW Speaker 4" bumper lights
  • JW Speaker headlights
  • Replaced factory horn with air horn
13781977_10153856189065658_176825375683614102_n.jpg 1239539_10151618079265658_1584208189_n.jpg 10300167_10152528415538627_3295916160941568003_n.jpg 14721578_10157602487505608_585352591263739507_n.jpg 10464142_10152121197880667_6102473261180720992_n.jpg 13095793_10153674729115658_7086088447125324043_n.jpg 15326588_10157850387900608_7997671153650808369_n.jpg
Upgrades to come:
  • SYE kit
  • Novak transfer case cable
  • Rear brake conversion
  • Front brake upgrade to dual piston calipers
  • etc., etc., etc....
Wow, that thing has come a long, long ways! I particularly like those wheels. It looks almost like you're running 35" tires with the profile of the wheel / tire combo. Looking really, really good!
Reactions: tjroughrider
Most recent upgrade/mod for the Jeep is. Purchased a new solenoid box and wiring from rough country (item #RS1). Instead of mounting in the usual spot on top of the winch, I mounted (temp spot) to the cross member on the hood. New location under the hood will be under the brake booster with the plug for the wired controller coming through the side of the hood. This way the hood doesn't need to be opened everything I need to use it. Pictures to follow...
Sent from my SM-N910W8 using Tapatalk
So here is the run down for the list of parts/accessories on order right now (this is an extensive list):
- 5-Staun Internal Beadlocks
- Metal Cloak RockSport Steering Stabilizer Kit
- TMR Customs Universal Transmission Crossmember Mount Kit
- Crown Automotive 55176180MK Body Mount Master Kit
- Factor 55 FlatLink E (Expert)
- Boomerang Enterprises AP-TJ-BLK Tire Tread Arm Pad Rest
- Amsteel 3/8" Synthetic Winch Line - 17,600 lbs 100ft Blaze Orange
- Neoprene Seat Covers (Driver & Passenger)
- Factor 55 Hawse Fairlead 1.5
- Alloy USA Dana 30 Chromoly 4340 Front Axle Kit
- Alloy USA Dana 35 Chromoly 4340 Rear Axle Kit
- Scrubblade 13 inch Heavy Duty Wiper Blades
- Wrangler NW Dual Battery Relay & Cable Kit
- Wrangler NW Dual Battery In-Cab Manager Kit
- Optima YellowTop D34/78 Batteries
- Armadillo Industries Billet Mechanical Door Straps
- Artec Industries Inner "C" Gussets (Dana 30)
- Borgeson Heavy Duty Replacement Lower Steering Shaft
- Borgeson Heavy Duty Replacement Upper Steering Shaft
- AEV Pull-Pal Winch Anchor - 11,000lbs
- Auburn Gear ECTED Electronic Activated Dana 30 Locker
- Auburn Gear ECTED Electronic Activated Dana 35 Locker
- Rock Krawler Rear Upper Adjustable Control Arms
- Rock Krawler Front Upper Adjustable Control Arms
- AIRAID Throttle Body Spacer
- Mastercraft Safety Nomad Suspension Seats
- Lock n Roll Trailer Hitch 2" Receiver (528 & 501)
- Red Peak Off-Road RubiCAM DVR Kit
- Garmin inReach Explorer Sat Communicator
- Bubba Rope Gator Jaw7/16 inch Soft Shackle
- Rugged Ridge Snatch Block Pully 30,000lbs
- Rugged Ridge 3" x 30' 30,000lb Recovery Strap
- 5-Pro Comp Steel Wheels (10" x 15" x 4" Backspacing)
- 5-Goodyear Kevlar Tires (35" x 15" x 12.5")
More to come after this list has arrived and installed.
Wow, did you win the lottery?
You can skip the throttle body spacer. Those are a complete waste of money. They don't work on modern fuel injected engines (not a myth, a fact): Do throttle body spacers work on Jeep Wrangler TJs?
Nah, didn't win the lottery. Although I wish, I could pay all this off quicker then. But it's all on order currently. Thanks for the heads-up about the throttle body space Chris.
I'm also going to be changing out the fuel injectors, swapping out the spark plug rail for a viper v10.
Who knows what else I will be doing this summer. Only time will tell.
I'm assuming that's a joke... the Viper V10 thing? Haha
