- Price
- 14,000 OBO
- Location
- Salem, MA
Looking at a few LJs and seeing if there is any interest in my TJ. I have been getting into some overlanding and would really like the extra interior room of the LJ so I may be upgrading soon. I haven't had this Wrangler long, but the list of work and upgrades is extensive. If this doesn't sell as is, I'll likely transfer a majority of these parts over to the LJ I pick up.
2006 Jeep TJ X
64,xxx miles
Deep Beryl Green
Last year of the TJs! Vehicle bought last April, less than one year ago, and completely gone through. All parts/mods completed from then to now. I think I honestly had more fun building this than I did driving it. It was a 2nd vehicle for me that is garaged. Roughly just over 10k invested in new parts/mods in the last 8 months with under 2k miles on it all. If the ad is up it is available.
I didn't attach too many photos because my build thread has a lot. Check it out or message me for specific photos.
Engine
4.0L
New Fel-Pro valve cover gasket
New Serpentine Belt
Oil changed
Transmission
NSG-370 6 speed manual
NP 231 Transfer case with Advance Adapters Slip Yoke Eliminator and Adams Drive Shaft
New Savvy shift cable
Fluid replaced in both
Body
New MCE flat fenders all the way around
New Rugged Ridge Rock Sliders/steps
Black headlight trim rings
Black grill inserts
JK style Turn signals
New Sahara Off-road Soft Top
New Smittybilt front stinger bumper
New MorRyde Heavy Duty tailgate reinforcement kit for heavy spare tire
New 1.25 Savvy Body lift
Carpet removed and inside floor/tub sprayed with liner
4 New Polk Audio Marine Speakers
New 8” Rockville Powered Subwoofer
Wheels/Tires
New Dick Cepek DC-2s x5
New Cooper Mud Terrains 33x12.5s x5
Suspension
New Old Man Emu 2.5” lift kit
New Rancho shocks and stabilizer
JKS Quick Disconnect sway bar links
All New Control Arms including Rear adjustable Core4x4 arms
4 New Spicer Ball Joints
All U-joints and Wheel Joints replaced
New Hub Bearings
Front brakes- New pads and rotors
Rear brakes (disc) New pads, rotors, inner drum kit for e-brake, & e-brake cables
New HD Steering ZJ Conversion tie rods and track bar
New Rear adj. track bar
Axles
Front Dana 30
4.10 gears
Inner axle seals replaced
Pinion seal replaced and new yoke
Differential cover seal and fluid replaced
Rear Rubicon Dana 44
Factory 4.10s with Locker and working locker pump
Carbon Alloy Axles
Fluid and seal replaced
Skid Plates (all new)
Rustys off-road radiator skid
Mountain Off-road full engine skid
Rough Country extra-clearance transmission skid
Front Differential Skid plate
Rear differential Skid/Slider
Powersteering box skid
Frame
Frame was clean to begin with (see photos) the following was a protective measure for NE weather:
Frame was stripped, etched and sealed with POR-15
Inside frame coated with Eastwood’s internal frame coating
Axles and suspension components were stripped and painted also
Accessories
Smittybilt Cargo net
Instatrunk
Tuffy under-seat lock box
Rough Country Seat Covers
Hi-Lift jack and Carrier bracket
Ramsey 8k lb. winch
Rain cover for when top and doors are off
Smittybilt tube/half doors
Door-off mirrors
Uniden CB with Firestick antenna
Grab Bars
Cell Phone Dash Mount
Molle Tailgate storage panel
Rear Tow Hooks
