This is for a 2008 Grand Cherokee, 3.7 V6.
AC system was leaking a bit last year, this year it's empty. So I got one of those high/low valve kits. The low side was easy, it had the standard valve. Then I searched around for the high side, found it at the top of a cylinder mounted next to the radiator. It does not have a valve inside, there's just a rubber plug in there.
As far as I know all the gauge sets you can get to pull vacuum and recharge are designed for the normal valves. So what the hell do I have? Pic below.
I'm pretty sure it was leaking from the low side port, but I was going to check that with a vacuum pump to see if it still leaks.
