Greetings! First post to the forum ... I know this topic has been written about and discussed ad nauseam, but I'm getting so much conflicting info ...
I have a 2017 Jeep Wrangler 4D Sahara, and the gear ratio is 3.2. The towing capacity is 2,000 pounds. I'm considering buying an Aliner camper, and the dry weight is 1,600 pounds. If I traveled with a full water tank, that adds 150 pounds ... Then there's the propane tank(s), battery, camping equipment, portable toilet, etc. I imagine I'll get close to 1,800-1,850 pounds.
Some folks say I should change my gear ratio to 3.7 or higher, just to be on the safe side. Apparently this will increase my towing capacity to 3,500 pounds. Of course, this has a negative effect on the gas mileage. Others say my Jeep is fine the way it is. Ugh. Help!!!
If I can avoid it, I'd prefer to NOT upgrade my gear ratio.
I welcome any and all advice!
Cheers,
Scott
Cheers,
Scott
