I love it!! What kind of rub do you get? Are your rims offset more than stock? I wanna Run em in stock 15’sView attachment 27779
33” x 12.5”. I need to sort the flares so they don’t touch on full compression
I don’t think 33”s will go without an offset. These are 3,75 off set if I remember correctly.I love it!! What kind of rub do you get? Are your rims offset more than stock? I wanna Run em in stock 15’s
I REALLY like this picture of your Jeep What bumpers are you running? An ARB rear?33x10.50x15 with a 3.5 lift.
Yes sir....an ARB rear bumper with swing out tire carrier and Hi Lift jack mount.I REALLY like this picture of your Jeep What bumpers are you running? An ARB rear?
Oh..... and a Body Armor front bumper with winch.I REALLY like this picture of your Jeep What bumpers are you running? An ARB rear?
Actually, I like the 33's better only because they are a bit narrower tire than the 32's and don't sling mud up the side of the jeep as bad. If they made a 32x1050x15 tire, I'd be all over that!
Thank you ...I REALLY like this picture of your Jeep What bumpers are you running? An ARB rear?
I hear ya on the spacer, Do you think it would be ok tho if used lightly? Jeep will be mostly streeted with an occasional trip thru the woods and some puddles.I don’t think 33”s will go without an offset. These are 3,75 off set if I remember correctly.
Personally I wouldn’t go with spacers. I’ve seen wheels nearly come of in the dessert because of failure.
There is likely a tire that size in a metric equivalent but, it will be in a 16" wheel.I wish they made a 32 x 9.50 or 10.5 wide tire as well. I use to have BFG KO’s in the 33x9.5 and they were a great traction tire. Plus they wouldn’t coat the sides of my 67’ Chevy in mud or gravel or slushy snow.
Spacers are fine... just gotta get the good ones (not cast) and check torque occasional... like every tire rotation.I hear ya on the spacer, Do you think it would be ok tho if used lightly? Jeep will be mostly streeted with an occasional trip thru the woods and some puddles.
'03 Sport running 32x11.50x15 KO2's with a 2" OME lift.
Love your rig. What top is that?
Rub? Spacer? Offset?
Any idea what the backspacing is on stock Ravine rims on an 04? I think I’m gonna go with the same tire, but I really like the look of a stock rimNo rubs. No spacers. No body lift. Wheels are 3.75" backspacing.
