stock ravine is 5.5" backspacing.Any idea what the backspacing is on stock Ravine rims on an 04? I think I’m gonna go with the same tire, but I really like the look of a stock rim
Ok so could you explain to a noob what I would have to do to fit that?stock ravine is 5.5" backpacking.
Fix the backspacing? You need to buy new wheels or buy spacers. Spidertrax and others sell wheel spacers that are about 1.25" thick. They will bolt on to the hub, and then you bolt the wheel to the spacer. Some guys don't like them, others don't care. I'm running JK wheels, so I had to get a set to adapt the 5 on 5" JK bolt pattern to the TJ's 5 on 4.5" pattern.Ok so could you explain to a noob what I would have to do to fit that?
Since it’s more of a beach cruiser/occasional puddle jumper, I’m not afraid of a spacer. So, if I used a spacer on a stock rim, I should be able to use the same tire without rubbing? I’m assuming any rub would come from control arm or something in the well, not from fender or flare. Is this right? 2 1/2 in lift should cover heightFix the backspacing? You need to buy new wheels or buy spacers. Spidertrax and others sell wheel spacers that are about 1.25" thick. They will bolt on to the hub, and then you bolt the wheel to the spacer. Some guys don't like them, others don't care. I'm running JK wheels, so I had to get a set to adapt the 5 on 5" JK bolt pattern to the TJ's 5 on 4.5" pattern.
i don't know lol canyon...ravine.......one of those things you don't want to fall into lol! its the rims i have in my profile pic. i think they're 8inch, now after talking to a "jeep friend" I'm leaning toward 33x12.5 pro comps.........i swear this is gonna make me insane lol.The Canyon wheels from my 2003 Sport had 5.25" backspacing. Not sure what the Ravine wheels are.
View attachment 27761 33" OME 2.5 HD lift with JKS 1.25" BL
Thank you. I am pleased with how everything has turned out.That is such a good looking ride......
LOVE this look.View attachment 28244 2.5'' lift 33'' x 12.5'' 4.56 gearing
I have come to agree that 33in is the "exxy-ist" look for a TJ. So, I have the 2.5 in lift installed,and I'm gonna do a small body lift...... with a 5-speed, I'm guessing I'm gonna lose a little steam, but it shouldn't be impossible to drive? am i wrong? Then i can work on doing a gear change when funds allow. What is all the other stuff you mentioned(SYE, tail shaft etc) and why do i need all that?Personally, if you aren't going to do gearing at the same time. Go 32's max, ours is a six speed and we never use 6th anymore (sometimes on the flat or downhill) going up another inch will make it worse. That said using the 6 speed as a 5 speed is more than ok in general use.
Where TJ's get really exxy, is when you want to run 33's or 35's with gearing changes and a lift over 2-2.5". Then you need, SYE on the transfer case, new rear tail shaft, plus adjustable top suspension arms. It's all stuff you only do once but it's stuff you really need to do at that level. Keep the build slightly smaller and you'll have a more usable vehicle.
I went with 3.25" lift, 33" BF Goodrich KO2, really impressed
Sent from my XT1575 using Tapatalk
I ll add it is a little doggy work the 3.73 gears but very driveable, but I don't pass many other cars. Rather than a great swap I d rather have an engine swap to something with a bit more horse and torque.I went with 3.25" lift, 33" BF Goodrich KO2, really impressed with the tires and one of the few you can get in a "C" range in that size, started with 15" wheels so there would be more rubber to cushion what I feel is an overly rough ride in the TJ,
Many appearance upgrades since this photo as well. View attachment 28447
