derekmac
I run them because I like the look of them.If i am wrong, then why are so many people running flatfenders vs stock fenders ??
^^^This^^^I think the question changed when people started telling him he was wrong.
The question has always been, is a body lift needed for 35’s. The answer is that depending on build and usage it may not be required.
For this poster it seems a BL is not required.
I did also get tired of having to straighten them out after most runs. Very tight trails and the factory fenders did not play well together for me. These also cost less than factory replacements, so that along with me liking the looks made the decision easy for me.I run them because I was starting to damage the factory fenders and flares. I know with a tremendous amount of certainly where mine do and don't provide differing amounts of clearance compared to stock. Once you go through the process of checking these things, one can start to read what is going on with other rigs.
No, the problem started the second you threw your $.02 into the ring. Everything was fine prior to that. You couldnt come to terms with “clearance” being the space around the fender/flare/tire.A body lift offers similar clearance gains as high clearance fenders. The problem here started when the OP convinced himself that his non-high clearance fenders were creating clearance that doesn't exist.
To be clear and factual, how much clearance is gained around the tire by swapping to a bolt-on flat fender from a factory fender.No, the problem started the second you threw your $.02 into the ring. Everything was fine prior to that. You couldnt come to terms with “clearance” being the space around the fender/flare/tire.
Its ok thou, several others got it, and now we can move on
Lets say a 33 inch tire in a factory fender with a factory flare.
VS.
A 33 inch tire in a bolt-on flat fender.
It is my understanding that 0 (zero) inches will be gained behind the tire towards the driver and passenger door.
It is also my understanding that 0 (zero) inches will be gained behind the tire in between the tire and the frame.
But yet, there are always a bunch of people that cant give you that straight up answer without interjecting that you are stupid and they are brilliant.
Now you guys are just being Dick swingers
How much more of a pulp are you going to beat this into ??
End of fucking story !!
All you need are flat fenders.lots of people running them
