35” tires without a body lift
Really?
I'm not gonna let it go. You let it go.
No you let it go.
No you let it go.
At this point none of us are winning the internet.
This whole shit storm could have been much better with some explanations of simple nomenclature.
Fact- the stock metal fender (not the plastic flare that bolts to it) has more clearance than any tubed flat fender. That's because the tire can move up into a cut out in the flare lip and come to within 5/16" of the top of the fender where you set your tools, beverage of choice etc..
Fact- there are no tubular flat top fenders on the market that don't use at least 1 1/4" tube, most are 1 1/2". They also weld to the bottom of the sheet metal that the fender is made from. That means the highest the tire can move up is minimum 1 1/4" less than stock, not more, and that is generally a 1 1/2" reduction in uptravel.
Fact- fuck the plastic flare, it is of no consequence in uptravel or clearance discussions. When the tire contacts it, it makes noise, it scares little girls, it does not and can not limit travel.
English, some of ya'll should learn it.
Little late to the party. Shitstorms over. Got the answer to my original question and moved on. Thanks for stoppin 👍
