As a comparison for the Pro 37" tires on small axle group. I ran them on my extended wheelbase TJ on Currie HP 9's front and rear. I'm the reason they don't recommend them for anything bigger than 35's. Wore out the rear gear set 2 times in 2 years. Front Ball joints 3 times. Couple sets front axle shafts, rebuilt the CTM u-joints at least twice.
We built a JK set to put under a TJ on 37's stretched out to 103 as an experiment.
Replaced the following so far.
Front ball joints 3 times, rebuilt the 600 dollar set of Dynatrac uppers once so far.
3 sets of front axle shafts and now RCVs which are getting noisy and clicking.
2 full sets rear axles. Wore out rear OEM locker, traded it for 35 spline ARB and a set of shafts. Now one of those is wobbling from over torque.
Wobbling shafts have ruined a set of rear brake parts.
Another rig on 37's, a TJ Unlimited has spent so much time at the tire shop trying to keep his tires balanced that he is going back to 35's and he never goes offroad.
Wheeled with a TJ on a HP 44 that broke an axle in JV with no spare so we were pulling him out in 3 wheel drive. The stress was high enough that when we were done we had to cut off and replace the inner C because it stretched out the upper hole so badly that the ball joint fell out.
TJ Rubicon on 37's. Little bump up an obstacle in JV, blew up the rear locker and it was the first day of a 9 day trip down from Washington. He towed it to town, got an ARB and new gears installed so he would finish his trip with us.
I've spent enough time and effort repairing, maintaining, and recovering stuff on 37's that shouldn't be that it will never be a good idea in my mind. Of course, your mileage may vary.
