- Price
- 3900
- Location
- Dallas
It's definitely a project but it has an (allegedly) new 32RH trans and no rust (that I could find). Has a metal cloak long arm kit with a 3-link up front. The tub been sprayed, but I banged on it a bunch and it felt solid, same with the frame. The frame hadn't been sprayed. Biggest issue is that there is some buggered wiring behind the dash and around the fuel injector areas. He says it cranks but won't start, but also didn't have a battery in it for me to even begin to diagnose. Has a hardtop that needs some fiberglass repair on the top.
I'm usually the outlier around here on these things, but I was ONLY looking at it to see if I could make it run and then flip for like $7500 (since I'm currently not working). The paint & interior make it a bad candidate for that sort of flip, but the wiring is a fairly easy fix. Definitely a good candidate if you're looking for a TJ to beat on. Also note the Antirock. If I didn't already have 3 jeeps in the driveway, I'd probably own it now.
Around here they only go for less than $6k if they have massive rust OR you make a 2hr drive outside the metroplex.
Let me know if the link doesn't work.
https://www.facebook.com/marketplac...ghtspeed_banner&referralCode=messenger_banner
