- Price
- 0
- Location
- Northern WI
I prefer local pick up on the large parts. I can load it into the back of a pick up truck for you. I will ship freight at your expense.
2004 4.0L engine. Under 86k miles. Includes original ECU, SKIM module, and programmed keys. Nothing is missing from this engine, no cut harnesses etc. I have maintained this engine meticulously since buying it with 19k miles. The oil and filter was always changed on or before schedule and an OEM air filter was used it's entire life. No leaks. Doesn't use oil or coolant. I have never had cooling, starting, etc issues with this engine. Runs really good! Includes new Durango 160a alternator, new OEM oil pan, and new OEM Mopar starter. I have oil analysis reports from Blackstone which show a healthy engine. Tentative price: $800 + Shipping.
Spare TCM (p56044764aa). Tentative price: $250. Available.
BoostedTech supercharger kit. This kit has less than 2k miles on it and the supercharger was replaced/rebuilt by BoostedTech and has 0 miles on it since. Includes everything to install on the 2004 4.0 listed above but can be used on 97-06 with minor changes (talk to BoostedTech about what you'd need to make this kit work with your year). Includes an ECU programmed for 2004 (PM me to discuss all of the ECU work that has been done). I have included new gaskets where needed so you won't need anything more. I'm also including the correct spark plugs (not included with the kit from BoostedTech). I have cut the intake tube that is included with the kit to make a custom intake which I think works better (sold separately, see custom intake below). Includes FTC data USB cable for custom tuning. Tentative price: $3200 + Shipping (this is roughly $600 off). Not yet available.
Tom Woods 1310 driveshafts. Less than 2k miles.
Boost, AFR, and trans temp gauges. Tentative price: 10% off new. Not yet available.
Exhaust pipe with bungs already welded in for AFR and EGT.
Also available is everything you need to run higher boost in your 4.0 (all of this is available today):
- $95 BoostedTech Medium Boost Pulley (BoostedTech charges $20 shipping, so I'm selling this for $25 less than they charge)
- $23 Spare idler pulley for BoostedTech kit
- $30 one size larger idler pulley for BoostedTech kit (priced higher because it's higher quality than the one above. Works with smaller steering pump pulley)
- Lots of belt sizes for the BoostedTech kit (I recommend buying all of these if you buy the kit since the one included may not work and if you change anything in the accessory drive you'll need to change the belt size) (see picture of available belts in post below)
- $105 Custom air filter setup for BoostedTech supercharger includes brand new spare filter (see pictures in post below)
- $85 MLS head gasket set (HS26211PT) (for running higher PSI) - new
- $25 Felpro Valve cover gasket (VS50458R) - new
- $27 Felpro head bolts (ES71102) (for running higher PSI, don't reuse head bolts.) - new
- $430 Harland Sharp 1.7:1 roller rockers - new
- $10 Redline Assembly Lube
- $75 Amsoil break in oil 1 case (12qt)
