Has anyone ever done a swap in their 4L TJ to the 5.9L Grand Cherokee Ltd?
Is it possible?
Is it a direct bolt in?
Is it possible?
X2I wouldn't do it. That 5.9 V8 in the Grand Cherokees is supposedly a big POS. That's just what I've read when I was doing the research.
If you're going to go through the effort of swapping in a V8, put in a Chevy V8 or a Hemi.
It's as close to "direct bolt in" as you're ever going to get for an early TJ Wrangler (1996-2000). OP, what year is your TJ? I am half way through this swap right now and have very little money in it because I have an entire ZJ Grand Limited donor vehicle for the swap. I might do an article on the conversion for those interested.Has anyone ever done a swap in their 4L TJ to the 5.9L Grand Cherokee Ltd?
Is it possible?
Rick
Did you ever finish the conversion? Did you sell the jeep?Has anyone ever done a swap in their 4L TJ to the 5.9L Grand Cherokee Ltd?
Is it possible?
We would like to see some pictures please?!I have the Jeep, It is down again for more axle and suspension upgrades. I had done several upgrades to Dana 44 axles and then changed my mind, went to Rock Jock 60 and selectable lockers instead of the Detroits. I am now upgrading the body with flat fenders, side armor and different rock sliders. Changing some things in the steering and redoing the lift kit I had on it. I integrated a tummy tuck so that was fairly involved but seamless with the engine conversion. Once this round of upgrades are done, she will be back on and off the road again, ready for action.
Even the 5.2L 318 C.I. V8 is no slouch compared to the 2.5L or 4.0L engine. Every bit helps sometimes when you have heavy armor, big axles and large heavy wheels and tires weighing in at well over 100 Lbs each. The rolling inertia to get those tires moving is where the V8 shines. On the average rock crawling trail, even the 4 cylinder sometimes has enough power.
Published specifications of the various motors:
2.5L 4 cylinder AMC design: 120 HP @ 5200 RPM and 143 Lb FT @ 3250 RPM
4.0L 6 cylinder AMC design: 190 HP @ 4600 RPM and 225-235 Lb Ft @ 3000-3200 RPM (variation is cylinder head dependent)
5.2L 8 cylinder ChryCo design: 220-230 HP @ 4400 RPM and 300 Lb Ft @ 3200 RPM (variation is due to exhaust & intake systems)
5.9L 8 cylinder ChryCo design: 245 HP @ 4000 RPM and 335 Lb Ft @ 3200 RPM
The 5.2L heads flow better, are less prone to cracking and can be adapted to the 5.9L engine. Aftermarket heads and intake can make the biggest gains on both motors.
The single biggest handicap on the 5.9L engine is the stock production cylinder heads and mild cam profile the factory gave them.
5.9L engines are externally balanced, the flex plate and flywheel from a 5.2L engine should not be used on the 5.9L or there can be moderate to severe engine RPM vibrations.
The 5.2L engine comes with a 44RE 4 speed transmission mated to it. This is a medium duty transmission that can be beefed up in several areas to make it much stronger. Any time this transmission is going to be rebuilt, it is a good idea to do all updates and strength modifications for a long life in severe duty 4WD V8 service.
The 5.9L engine comes with a 46RE 4 speed transmission mated to it. This is a heavier duty transmission than the 42RE behind the 6 cylinder engines or the 44RE behind the 5.2L V8. It has a larger input and pump assembly and several other internal upgrades that are similar to the TF727. This transmission also has several updates that should be done if you are going to rebuild it as well. It is the better of the family and will work behind the 5.2L V8 provided you use the correct flexplate and torque converter for an internally balanced engine.
As I mentioned before, the JTec Jeep ECMs all use the same pinout configuration and the difference in the 1990's and early 2000's Jeeps is in the harness wire count, length and connector configuration at the various sensors. IE: the TPS (Throttle Position Sensor) may have the wiring switched from pins 1, 2 & 3 to 3, 1 & 2 for Ground, signal and Voltage feed. The alternators are still controlled by the ECM for charging and regulation, and the way the ASD (Auto ShutDown Relay) is wired into the harness may vary. Overall on many engine swaps, the number of actual changes needed to the Jeep TJ harness numbers around 15 to 18, with the plugs on the various sensors being a big chunk of that.
Yes @billiebob true dat! What MOPAR calls a Hemi today is in fact not a true Hemispherical combustion chamber engine. It's closer related to a "Wedge" motor. However, they are definitely more efficient and make gobs more power so If I owned a 2005 or 2006 TJ/LJ Wrangler, I would install an early production 5.7L Hemi instead of the Magnum family of reworked LA series engines. I would also choose a more modern automatic transmission to go with that newer engine with more gearing options.
@Rangerrick what flywheel would you use for a 5.9 magnum mated to an ax15 tranny?
Yeah. I was hoping to stick with LUK. I found a Brute Power at Autozone. Not excited about it but it should do the job. It's just a hunk of metal. What could go wrong right? I bought a 12" Sachs clutch set to go along with it.The LUK flywheels are on BO right now.
https://www.partsgeek.com/catalog/2000/dodge/ram_2500/clutch/flywheel.html
Summit has a nice bunch of choices. They still have the LUK in stock. It is the preferred brand for clutches for the TJ so I'd say the same should follow for the Ram.
https://www.summitracing.com/search...9l-360/engine-family/mopar-small-block-magnum
